Does anybody know if you add one of the virtual DJ skin , can you still use the regular version 8 layout as well ? I'm thinking it would be nice to have the ability to try a skin for a while b4 I commit 100%
Thanks in advance
Thanks in advance
geposted Wed 18 May 16 @ 10:21 pm
You can add as many skins as you like, then swap seamlessly between them in config.
geposted Thu 19 May 16 @ 5:36 am
