Forum: VirtualDJ Skins
Topic: Using to produce different coloured buttons
alucasCUE userMember since 2008
Is it possible to <define> a <button> that has a different <on> position depending on whether it's used on the left or right deck? I tried this:
<define class="select_deck">
<pos x="+0" y="+0"/>
<size height="60" width="60"/>
<off x="96" y="2149"/>
<over x="226" y="2149"/>
</define>
<define class="select_deck_A">
<button class="select_deck">
<on x="161" y="2149"/>
</button>
</define>
<define class="select_deck_B">
<on x="294" y="2149"/>
</button>
</define>
but that didn't work. Perhaps you can't nest <defines> like this.
geposted Fri 27 May 16 @ 1:51 am
FruitPRO InfinityMember since 2003
like this :
<define class="select_deck" classdeck="left">
</define>
<define class="select_deck" classdeck="right">
</define>
geposted Fri 27 May 16 @ 4:38 am
Thank you for that solution. It would be nice if there was a way of doing it without duplicating the data that is in common. For example, with your suggestion, if I want to change the size I have to remember to do it in two places.
geposted Fri 27 May 16 @ 9:15 am
</define>
<button class="select_deck"><on x="161" y="2149"/></button>
<button class="select_deck"><on x="294" y="2149"/></button>
You can also do it like this but :
In the first example it's usual to put the two buttons's code at the same place in your xml (let's say in a "buttons" group), whereas in this 2nd example, the buttons will belong to <deck> beacons or some panels that could make them far from each other (and so more difficult to modify later).
geposted Fri 27 May 16 @ 10:40 am
You can't nest definitions.
However, there are ways to overpass this depending on what you want to achieve.
The most common way is to override an attribute when you call it:
DEFINITION:
<define class="selectdeck" action="select" >
<on x="96" y="2149"/>
<off x="96+60" y="2149"/>
<over x="96+60+60" y="2149"/>
</define>
CALLS:
<button class="selectdeck" deck="1"/>
<button class="selectdeck" deck="2"><on x="96+60+60+60" y="2149"/></button>
PS: Generally when defining items it's a good idea to hold them together when you use classdeck:
<define class="bt_PFL" action="pfl" rightclick="select" classdeck="1">
<size width="32+4" height="17+4" />
<up x="1515" y="1450"/>
<mouserect x="+0" y="+0" width="32" height="17"/>
<text width="32-4" height="17" dx="+2" dy="+0" size="12" align ="center" scroll="no" color="#808080" weight="bold" format="PFL" />
<textselected width="32-4" height="17" dx="+2" dy="+0" size="12" align ="center" scroll="no" weight="bold" color="#008ce1" format="PFL" />
<tooltip>Select this deck to prelisten \non headphones</tooltip>
</define>
<define class="bt_PFL" action="pfl" rightclick="select" classdeck="2">
<textselected width="32-4" height="17" dx="+2" dy="+0" size="12" align ="center" scroll="no" weight="bold" color="#e60000" format="PFL" />
</define>
<define class="bt_PFL" action="pfl" rightclick="select" classdeck="3">
<textselected width="32-4" height="17" dx="+2" dy="+0" size="12" align ="center" scroll="no" weight="bold" color="#28c800" format="PFL" />
</define>
<define class="bt_PFL" action="pfl" rightclick="select" classdeck="4">
<textselected width="32-4" height="17" dx="+2" dy="+0" size="12" align ="center" scroll="no" weight="bold" color="#ffd700" format="PFL" />
</define>
This way it's easier to handle. And when you do changes you just copy/paste them on rest defines
geposted Fri 27 May 16 @ 10:44 am
OK - thanks for your help.
geposted Sat 28 May 16 @ 1:26 am
