As per suggestion in this thread
http://www.virtualdj.com/forums/209870/VirtualDJ_8_1_Technical_Support/Adding_files_to_nested_vFolders_via_script.html
Can we please get or extend the existing virtualfolder_add action to work with subfolders?
If you are working with subfolders at some point it gets too messy to have them all in the root of the VDJ browser.
So you will collect them in another virtual folder but then your action(s) do not work anymore.
There is another action where the "Parent/Subfolder" notation already works, but I don't remember it atm.
Even if you are not using many actions, but just one for your "cool new stuff I have to play" virtual folder. It is way easier to press your mapped button to add this track to the vFolder while browsing your collection, than first bring the vFolder into focus and then drag and drop it with the mouse.
geposted Sat 28 May 16 @ 6:36 am
Will add this.
As a workaround, it is possible to do this by already if you write the virtual folder as "Parent.subfolders/Subfolder"
geposted Sat 28 May 16 @ 7:12 am
Thank you. Really appreciate that.
geposted Sat 28 May 16 @ 1:12 pm
