Forum: VirtualDJ 8.1 Technical Support
Topic: SECOND SCREEN FOR VIDEO
Any one can help me to SETUP the second screen in VDj 8... Virtual Dj 8 Do NOT recognize my second screen anymore. Videos only pop out in my laptop
geposted Sat 28 May 16 @ 6:34 pm
You haven't really given any info to diagnose.
Check your display settings on the PC and your cable.
geposted Sat 28 May 16 @ 6:56 pm
If the Video Master Preview Window popsup on the primary screen, cant you drag this window and drop it to the 2nd screen ? If you can then double-click inside the window so that it gets fully maximized.
Then close VirtualDJ and try to see if it memorized this.
Btw, are you on Windows or Mac ? Is the 2nd screen in "Extended" mode ?
geposted Sun 29 May 16 @ 3:18 am
