Forum: VirtualDJ 8.1 Technical Support
Topic: Copying VDJ7 Mappings to VDJ8
Hi Experts !
I am currently running both VDJ 7 and VDJ 8 on the same PC, i want to move my mapping for the versadeck from VDJ 7 to VDJ 8, tried searching but there doesnt seem to be a straight answer. is there anyway to do this without remapping again in VDJ 8?
thanks
Chad
geposted Fri 03 Jun 16 @ 3:01 pm
If both versions are on the same PC then there is nothing to do.
Version 7 and 8 share the same folder for mapping files.
It is at ../Documents/VirutalDJ/Mappers
You should be able to select your (custom) mapper from within VDJ already.
If you don't have, or can use, a custom mapper because of version limitations just use the VDJ default mapper. The Versadeck is natively supported.
geposted Mon 06 Jun 16 @ 8:34 am
thanks !
geposted Mon 06 Jun 16 @ 4:35 pm
