Hello
Is there any place where I can get the new 8.2 default skin in a zip, so I can do my little tweaks :)
It doesn't look like it's in the skin folder...
/Klaus
/Klaus
geposted Mon 06 Jun 16 @ 1:48 pm
geposted Mon 06 Jun 16 @ 2:23 pm
Sorry, I don't have this button (MAC Version):
geposted Mon 06 Jun 16 @ 2:28 pm
Click on "Default" line instead
geposted Mon 06 Jun 16 @ 2:43 pm
Thank you!
Was that also there in v8.0 and v8.1?
In that case I should have known :)
geposted Mon 06 Jun 16 @ 2:54 pm
Doesn't work, sorry. This button doesn't appears (on MAC) :(
geposted Mon 06 Jun 16 @ 3:16 pm
This button doesn't appears (on WIN) :(
geposted Mon 06 Jun 16 @ 3:21 pm
It did on mine when I chose the default skin
geposted Mon 06 Jun 16 @ 3:28 pm
Works for me on windows too. .....
geposted Mon 06 Jun 16 @ 3:31 pm
klausmogensen wrote :
Thank you!
No, it's new to 8.2
geposted Mon 06 Jun 16 @ 3:52 pm
For anyone that can't see the button: Catch the lower right corner of config window in order to resize it and drag towards right in order to increase width. Does the button comes up ?
geposted Mon 06 Jun 16 @ 3:56 pm
yes! you're the man! Thank you.
BTW: I like the new mapping gui + functions. good job :)
geposted Mon 06 Jun 16 @ 4:05 pm
How to remove the lines and my auto hide from my docking keep coming down when VDJ open it's off my my Mac.and when open VDJ is VERY small in the left side of my screen.
geposted Mon 06 Jun 16 @ 5:27 pm
Are these lines on default skin ? (Because I see black background and default skin has gray background instead)
geposted Mon 06 Jun 16 @ 5:30 pm
No! Tested on Mac b3236. Earlier build this work around worked.
geposted Wed 15 Jun 16 @ 3:21 pm
You don't have the default skin selected ;)
geposted Wed 15 Jun 16 @ 3:59 pm
And just to be clear, by "default" we dont mean the VirtualDJ 8 skin that you may have from previous versions, its named as "Default" and its at the top of the skins list ;)
geposted Wed 15 Jun 16 @ 5:14 pm
OK,ok my mistake.
Sorry for this.
Sorry for this.
geposted Wed 15 Jun 16 @ 8:22 pm
