Hi all,
Ive just updated to 8.2 - looks great.
The pads are something ive been after for years. I have previously used custom buttons using the default vdj8 skin.
Now there are pads next to the decks, is there any way to remove the 'loop' and 'effects' section/buttons that are there by default - so i just have the deck and the custom pads?
thanks.
thanks.
geposted Mon 06 Jun 16 @ 7:08 pm
If you mean to hide the "Loop" and "Effect" sections of the skin, I'm afraid not. At least not without editing the skin!
geposted Mon 06 Jun 16 @ 7:30 pm
