I can't seem to find how to bring back the full color palette in the Tag Editor. How may I accomplish this? Please don't tell me we are limited to 15 colors.
UPDATE:
Going back to 8.1. I just messed up a "Pink" coded track with a darker color. I need the full palette back please.
UPDATE:
geposted Tue 07 Jun 16 @ 6:07 am
geposted Wed 08 Jun 16 @ 3:34 pm[ selected best answer by Stephane Clavel on Wed 08 Jun 16 @ 3:35 pm ]
Yup same problem here for me to.
I color my tracks by key and now I can't even do that anymore because the color palette is not showing up..
geposted Tue 07 Jun 16 @ 11:04 am
I have the same here. Maybe this is related to the new coloured cues - they've limited the colour choice so the coding is easier (I guess).
geposted Tue 07 Jun 16 @ 5:01 pm
Ok we'll bring back a way to choose more colors
geposted Tue 07 Jun 16 @ 6:20 pm
I could live with this 15 color palette for the new CUE mark coloring capability. But I've been using a wide range of colors so far in 8.1 with my tracks.
I go from "bold" to "pastel" in color choices. It is a beautiful thing to assign colors in order to identify the "heat" of the track.
Please bring back the 8.1 color palette. My upgrade to 8.2 is on hold.
UPDATE: Just saw Teamer's message about bringing back the 8.1 palette. THANK YOU!!!
geposted Tue 07 Jun 16 @ 6:28 pm
Enabling "more colors" isn't necessarily bringing back the whole palette!
It's a shame. The ability to colour cues was great, being able to set a precise colour shade with hex codes. Looks like that's gone now, with such a limited fixed selection.
geposted Tue 07 Jun 16 @ 6:48 pm
Thanks for going back.
geposted Tue 07 Jun 16 @ 7:00 pm
@groovin: and that's what we'll bring back, the possibility to write hex codes, so you get the full 16 million possibilities.
geposted Tue 07 Jun 16 @ 7:06 pm
I just need 24 for my harmonic keys :-)
geposted Tue 07 Jun 16 @ 7:12 pm
+1 for reverting back to the old palette. I miss my colors :(
geposted Tue 07 Jun 16 @ 9:30 pm
Please bring back the option to input RGB numbers and palette as before - none of the colours showing now match any of my current colours so in turn my filter folders won't work as they are based on RGB numbers. Thanks in advance...hopefully!
geposted Wed 08 Jun 16 @ 10:22 am
With the latest EarlyAccess build (b3217 or bigger), right-click on the color picker to enter a RGB color directly.
Selected as best answer geposted Wed 08 Jun 16 @ 3:34 pm
It is still much quicker if the full palette is available as not everyone tends to memorise the # code but do the actual RGB numbers, e.g. 255,15,15 for a specific shade of red but I have had to look up the #code from another file before being able to use that on a new track. Just my thoughts of course but I would definitely still prefer it if the colour picker was as in 8.1.
geposted Wed 08 Jun 16 @ 3:54 pm
You realize that the # code is the actual RGB numbers, right? :)
(though for next build we'll add that you can also write it in decimal as "255,15,15" instead of the usual hexadecimal notation "#FF0F0F")
geposted Wed 08 Jun 16 @ 4:40 pm
Yes I do know that is the actual code but find it easier to remember the decimal numbers rather than the FF string, as I said, just personal preference.
geposted Wed 08 Jun 16 @ 4:57 pm
Is it not just possible to click on a palette and it chooses the colour for you?
That's what happens in most other software.
As a normal user I have absolutely no idea about either of these hex codes or numbers.
VDJ needs to be written for normal DJs not programmers or graphic designers.
geposted Wed 08 Jun 16 @ 5:05 pm
Was just gonna say the same thing........
geposted Wed 08 Jun 16 @ 5:15 pm
....in other words we want this back.
geposted Wed 08 Jun 16 @ 5:20 pm
"Don't fix what's not broken" - http://www.phrases.org.uk/meanings/if-it-aint-broke-dont-fix-it.html
geposted Wed 08 Jun 16 @ 5:32 pm
Awwwww... shucks. Build 3236 I see allows a "right click" to get a pop up box for entering color HEX characters. How about a way to get to the color palette. It's soooohhhh..... much easier than remembering the HEX value for PINK or MEDIUM GREEN. Reverting back.
geposted Sun 12 Jun 16 @ 7:25 pm
