Topic: Using a External Monitor
I did the 8.2 early update yesterday and when I played video on a other monitor I was unable to look into song files, option screen, and bpm screen when ever I opened one of them the screen would flicker and I was unable to do anything but shut it down and restart . needless to say I went back to the older version still some kinks to work out. Good luck and looking forward to the new version.
geposted Tue 07 Jun 16 @ 9:29 pm
You say previous version is okay, which version? 8.1? 8? 7.xx??
Have you updated your DirectX 9 to latest version??
The easiest way to do this is to install the latest version of Milkdrop8 HERE
geposted Wed 08 Jun 16 @ 2:26 am
I was having the same issue when FULLSCREEN, where it flickered with 8.2. 8.1 and older versions worked just fine.
My solution is to set the Video: videoForceFullscreen = 0. I would have thought 1, would be okay...but it just doesn't work. 0 does.
geposted Wed 08 Jun 16 @ 3:28 am
Same here with forcefullscreen 1. But I have to stick with 1, because of tearing. So I can't use it anymore... :-(
geposted Fri 15 Jul 16 @ 6:48 pm
