Topic: TAG Editor & Karaoke Checkbox[SOLVED]
Updated to b.3217 earlier today and have noticed that I cannot check or uncheck the Karaoke option in the Tag Editor - I am not sure if it worked on the first v8.2 builds released and I only had cause to use it today. I am using DJTouchDan's Browser Zoom skin, VDJ Pro Infinity, Win10. Have also tried on the Default skin and still no joy. Anyone else getting this issue?
geposted Wed 08 Jun 16 @ 8:00 pm
Yes,same here (Focus skin)
+1
Am hoping that this has been reported as a bug...
yes, its been reported/noted.
Fab, thank you :)
Should have been fixed in the latest Early Access Build 3268
