I know this is a beta and NO gigs this weekN but when I plug my SX-2 to the NEW VDj- 8.2 this is what a get will not open,the last 2day I was trying to get to know the NEW SW 1st before the controller in use. The Video. https://youtu.be/5aE0K9Jh22k
geposted Thu 09 Jun 16 @ 1:25 am
Does VirtualDJ launch without the SX2 ?
Try to remove your custom mapping from the Mappers folder and re-launch.
If the SX2 is not related, try to remove the settings.xml from the VirtualDj folder and relaunch.
geposted Thu 09 Jun 16 @ 4:34 am
Yes it works with Sx2 hook up and when I remove the Mapper VDj 8.2 open OK,so 2yr of setting this controller were its just right ( map ) I need to redo it to new that 8.2 .or can't I just go in the XML or send my XML you VDj support.
geposted Thu 09 Jun 16 @ 5:31 am
done there is 2 the original I replace it with the copy/old back up and same thing results
geposted Thu 09 Jun 16 @ 1:23 pm
The redo/new mapper you send work ,what was it
geposted Thu 09 Jun 16 @ 11:29 pm
in the ONINIT you had something like ...
open settings when 1
which first is not a valid vdj script and second, opening settings on init is not the best choice ;)
geposted Fri 10 Jun 16 @ 12:44 am
Ok Thank you
geposted Fri 10 Jun 16 @ 1:11 pm
