For reporting any bug, questions or comment related to the latest version of VirtualDJ
(NOTE: VirtualDJ continuously updated, so many older topic on this forum are most probably already fixed in the current build)
If you need extended support, contact our Support Team.
Forum Guidelines  (*) The moderators hold the rights to move or modify posts in order to keep the discussions clear or to facilitate the search.
Topic: Pioneer DDJ-SZ vinyl mode on off[SOLVED]
Before on my DDJ SZ was toggling between on and off vinyl mode by pressing SHIFT and SLIP. After upgrade to ver. 8.2 is not working anymore.
Regards Tomas.
geposted Fri 10 Jun 16 @ 4:57 pm
Is this the case for the factory default mapping or just with your own custom one ?
In Settings-->CONTROLLERS tab when you pres SHIFT+SLIP do you get the VINYL key or the SHIFT_SLIP in the Key Learn section ?
Map what you get there as vinyl_mode
geposted Sat 11 Jun 16 @ 12:06 am
Thank you DJDad. That solved my problem.
Regards Tomas.
geposted Sat 11 Jun 16 @ 5:04 pm
The default mapping is updated in the latest Early Access, with a fix on the SHIFT+SLIP. However, this probably applies to just the factory default mapping. See how its mapped in order to apply this to your custom mapping.
geposted Mon 20 Jun 16 @ 2:37 pm
