For reporting any bug, questions or comment related to the latest version of VirtualDJ
(NOTE: VirtualDJ continuously updated, so many older topic on this forum are most probably already fixed in the current build)
If you need extended support, contact our Support Team.
Forum Guidelines  (*) The moderators hold the rights to remove, move or modify posts.
Topic: automix editor selection and crashing [SOLVED]
went into automix editor and selected track, edited, went to next track and first track remained blue and then the weird stuff started happening - other tracks would highlight blue but not the next down from original track selected and then after trying to select the other tracks it would after a few clicks vdj would restart but music would not continue.
geposted Fri 10 Jun 16 @ 9:46 pm
same issue here. Can replicate.
geposted Sat 11 Jun 16 @ 7:03 am
Should have been fixed in the latest Early Access Build 3268
geposted Mon 20 Jun 16 @ 2:47 pm
