Forum: VirtualDJ 8.1 Technical Support
Topic: Runtime Error on closing
I've just updated from 8.0 to 8.1 and whenever I close out of the program I get a Runtime Error. How do I fix this?
Thanks.
Edit. Also happens when I try to select docking of Essential Visuals effect.
geposted Sun 12 Jun 16 @ 1:27 pm
Sounds potentially like a problem with that effect then - you may want to update it or test with it removed.
geposted Tue 14 Jun 16 @ 7:45 am
Yeah it does. Never had any trouble with it in 8.0, so I've reverted back for the time being.
Thanks.
geposted Wed 15 Jun 16 @ 2:29 pm
