My keyboard mapper work some time and my controller mapper also (browsed_file_color "Red" or green,red ) Shift+ color and Show_splitpanel 'side view' off the controller
geposted Mon 13 Jun 16 @ 1:06 am
browsed_file_color 'ColorName' works fine here.
As for the 2nd action, it should be Sideview not side view., so ...
show_splitpanel 'sideview'
geposted Mon 13 Jun 16 @ 5:09 am
And Don't save the Color also...
geposted Mon 13 Jun 16 @ 2:23 pm
Im sorry when you close VDJ then open it back up the color is not save.
geposted Mon 13 Jun 16 @ 2:33 pm
And Cue's points also don't save when you close and reopen I was thinking it was me last night when I was making a mix for a Promoter for a gig
geposted Mon 13 Jun 16 @ 2:44 pm
Check your settings for the "readOnly" setting. If it's set to yes change it to no and restart VirtualDj
geposted Mon 13 Jun 16 @ 3:20 pm
