Topic: Ask the DJ ideas
ewitlesPRO InfinityMember since 2006
Ask the DJ ideas...
I see the request part can get out of hands but where I really see this as useful when working complex events (weddings, etc) and the planner/venue captain needs to relay a message to you.
Give the important folk the url/txt and save them the trouble of running around trying to TELL you.
This is a PERFECT way for them to say 'time to introduce the bridal party' or 'announce last call'.
Maybe 'sell' that point instead and make it easier when you get a notification.
Sure wish I had this for several weddings I had done.
geposted Mon 13 Jun 16 @ 4:40 pm
Love the ideas! +1
geposted Mon 13 Jun 16 @ 4:56 pm
Someone on djtechtools mentioned a direct link between Ask the DJ and your Paypal account.
That is a great idea if you ask me :D
geposted Wed 15 Jun 16 @ 10:25 am
Ask The DJ should also be in the sideview, instead of being in the root tree.
Another good thing would be Facebook integration with the hashtag, just like in Twitter.
geposted Thu 16 Jun 16 @ 11:03 pm
I'm sure you tested this out before writing this post but you made me wonder so I wrote a short Lewd message and it came up. What I need to find out is how to change the refresh rate on it, and as multiple people are saying is this needs to be an option on the side menu
geposted Fri 17 Jun 16 @ 5:41 am
The refresh rate is hardcoded. It should be around 5 seconds.
geposted Fri 17 Jun 16 @ 11:47 am
A new message light some ware on the skin would be a good idea, in case you don't have the root view open
geposted Tue 21 Jun 16 @ 10:23 am
wblairPRO InfinityMember since 2010
I second this post..... A new message light some ware on the skin would be a good idea, in case you don't have the root view open
geposted Tue 21 Jun 16 @ 3:01 pm
It's now in options: askTheDJFrequency
It's already the case.
Just need to right click on the askTheDJ folder, and select monitoring->always ;)
geposted Tue 21 Jun 16 @ 3:45 pm
CannenPRO InfinityMember since 2016
I haven't seen or used this feature before, but could you open up the app in the root tree and then on the bottom of your sidelist, add it as a favorite? Not sure because I haven't used it. Just a thought.
geposted Tue 21 Jun 16 @ 8:29 pm
Cannen wrote :
".....but could you open up the app in the root tree and then on the bottom of your sidelist, add it as a favorite?"
You can.
geposted Wed 22 Jun 16 @ 7:43 am
Hi I have been using Ask the DJ for about 2 weeks and found that having both Http://ask/the/dj and using Twitter at the same time was great but the last update has stopped that is there a way to have both setup at the same time. Using both options is very helpful to stay in connected with the crowd, so if poss can we have both options with a on/off tab in settings please. Just to say Ask The DJ was a great update and many thanks for you hard work.
geposted Thu 23 Jun 16 @ 2:03 pm
No, there is no way to monitor both at this time.
geposted Thu 23 Jun 16 @ 2:21 pm
blckjckPRO InfinityMember since 2008
I would like a way to pull the incoming messages and display them on the screen. Being able to monitor and approve them would be important. Even better would be if other plugins could get the information, like TellyVisuals.
Also, how about adding a log option to save the messages.
geposted Thu 23 Jun 16 @ 6:00 pm
