Clicking the 'Edit Cog' in the browser causes VDJ to crash.
Click 'SAMPLER'>'DIGITAL TUNNEL' so Digital Tunnel appears in the browser window, then click 'EDIT COG'.
VDJ8.2
V.3236
Windows 10 (64-bit)
VDJ8.2
V.3236
Windows 10 (64-bit)
geposted Mon 13 Jun 16 @ 8:58 pm
when you say "edit cog" do you mean this? Look at the photo where the arrow is at
geposted Tue 14 Jun 16 @ 1:21 am
probably same issue with this post:
http://www.virtualdj.com/forums/210276/VirtualDJ_8_2_Technical_Support/Video_Sampler.html
geposted Tue 14 Jun 16 @ 1:25 am
That is the cog I am referring to. I don't think it's the same issue as the other post as the crash happens when I click the cog.
geposted Tue 14 Jun 16 @ 9:44 am
Yes it is. Anyway it has beem replicated by the team.
geposted Tue 14 Jun 16 @ 10:36 am
Ok. Thank you.
geposted Tue 14 Jun 16 @ 11:44 am
Should have been fixed in the latest Early Access Build 3268
geposted Mon 20 Jun 16 @ 2:40 pm
