Topic: slidehow pulsing brightness
ive noticed (after a fresh install) the slideshow plugin pulses the brightness of the displayed picture on the video out.
Am i missing something?
Ive got milkdrop 8 so that would've installed the latest DX9c extensions. what else does it need please??
geposted Thu 16 Jun 16 @ 10:22 am
what are your values for the Speed and Fade Parameters of the Slideshow ?
If milkdrop not enabled or not selected as AudioOnlyvisualisation) makes any difference ?
geposted Fri 17 Jun 16 @ 12:16 pm
djdad wrote :
what are your values for the Speed and Fade Parameters of the Slideshow ??
Theyre set to whatever the default was, so speed=3s fade=1s..
I'll turn these off on my gig system, cant check on test system as i cant open file requestor to select a picture in current review build..
geposted Fri 17 Jun 16 @ 12:59 pm
