Topic: VDJ 8.2 Skin no well fitting
My laptop resolution is 1366x768. I'm using Intel graphics HD 4000. It's a 14" Sony Vaio SVE.
As you can see the original skin looks terrible on my laptop. So for now I'm using a custom skin(1366x768) which looks perfect. But I want to use the original.
Any sugestion?
https://s32.postimg.org/6hfmysgrp/vdj.png
geposted Thu 16 Jun 16 @ 1:19 pm
Might try adjusting 3D to quality in graphics settings
It helped on mine.
geposted Thu 16 Jun 16 @ 2:18 pm
Ok guys I have just solved it. I did a factory reset on VDJ and now it's good. Thanks.
geposted Thu 16 Jun 16 @ 10:23 pm
