Topic: Bug regarding embedded cover art
Using filter folder "exists = 1 and Album Art = 0" gives a list of files with no cover art.
If you do a scan (or batch scan) the embedded cover art does not get picked up by VDJ. You have to go to tag editor for each individual file then rescan before the art gets registered as being there.
geposted Fri 17 Jun 16 @ 8:41 am
Scan has nothing to do with Cover art. It scans for BPM, Gain and Key
You need to use Batch->Reload Tags instead
geposted Fri 17 Jun 16 @ 9:55 am
So it are files that had cover art added outside of vdj?
geposted Fri 17 Jun 16 @ 9:57 am
D'oh. I'm not having a good day today. Off back to bed ......
Yes, cover art embedded in the MP3. Reloading the tags worked perfectly.
Thanks George!
And if I'm not mistaken, if vdj finds a file with no cover art AND there is an internet connection, it will auto search one out and fetch the first result (which might not always be the best)
every now and then i have to edit these by hand
geposted Fri 17 Jun 16 @ 1:02 pm
Depends on the coverDownload setting
geposted Fri 17 Jun 16 @ 1:05 pm
