I'm getting the message when I load a video in 8.2 "Decompressing this file in memory would require 40mb of contiguous memory..." How or where can I adjust that so I don't get that message anymore. I knew how to do it with the reg tool in 7 but I wouldn't know where to start in 8.2? I have a video gig tomorrow... Can someone please point me in the right direction?
geposted Fri 17 Jun 16 @ 4:44 pm
Whats the name and model of your video card?
geposted Fri 17 Jun 16 @ 6:18 pm
NVIDIA GFORCE GTX 680M
Laptop Alienware M17XR4
12g ram
12g ram
geposted Fri 17 Jun 16 @ 6:24 pm
i'm also getting this warning HELP!
geposted Fri 23 Dec 16 @ 8:18 am
I also get this msg on 1h+ videos. Even if only one deck is loaded.
My video card's got 8Go of ram :/
NVidia GeForce GTX 1080 Asus strix OC.
geposted Fri 23 Dec 16 @ 11:25 am
I have just loaded 2 x 60 minute videos in decks 1 & 2 with no issues whatsoever.
Win 7, Intel HD5500
Win 7, Intel HD5500
geposted Fri 23 Dec 16 @ 12:12 pm
@funkmasterfrank what (automatic) value do you get for setting VideoMaxmemory ?
geposted Fri 23 Dec 16 @ 3:06 pm
The relevant setting here is maxPreloadLength
geposted Fri 23 Dec 16 @ 5:08 pm
I'm also getting this with 3GB ddr5 ram and it set on auto for maxpreload. It never did it before. Gtx 970m vid card
geposted Sun 29 Jan 17 @ 4:42 am
I also have this problem that the auto cuts out
Msi 12 gig ram
6 gig video nivadi Geforce gtx 1060
Msi 12 gig ram
geposted Mon 28 Aug 17 @ 9:18 pm
Having this same issue on my new laptop
System:
Windows 10 Pro (10.0.16299 Build 16299
16gb RAM
Intel Core i7-8750 CPU @ 2.2GHz 6 Core 12 Logcial Processors
NVidia GeFroce GTX 1050 ti 4GB Ram latest drivers I even rolled back and tried 2 previous versions
Any more news on this.
geposted Sun 10 Jun 18 @ 2:40 pm
I set this to -1 and was still able to reproduce the issue. Am I mis-understanding? What would you recommend the setting be?
geposted Sun 10 Jun 18 @ 6:15 pm
Maybe if you told us exactly what type of file you're trying to load?
You know - file type, codec, size, playing time, resolution.
geposted Sun 10 Jun 18 @ 6:56 pm
Sure all Karaoke related (.mp3 with the .cdg named the same in the same directory). Happens after about the 3rd or 4th selection)
So playing times will vary for each selection; but the crash is consistent.
geposted Sun 10 Jun 18 @ 7:19 pm
