Forum: VirtualDJ 8.1 Technical Support
Topic: Activate Controller?
eschu35ControlleristMember since 2016
So i just purchased the $99 license to actually use my controller, but the controller is still blinking and changing colors as if it hasn't been installed correctly or something. If anyone knows how to activate the controller after purchasing the license please let me know.
geposted Fri 17 Jun 16 @ 9:01 pm
Do you not think it might be wise to mention what controller you have?
geposted Fri 17 Jun 16 @ 10:52 pm
Make sure you have installed the drivers for your controller first. Once installed VDJ will recognize your controller and you should be sweet to go
geposted Sat 18 Jun 16 @ 11:32 am
It appears that you have purchased an incorrect Plus License.
Please contact support to arrange for an internal license change
geposted Sun 19 Jun 16 @ 11:20 am
Got my license changed but controller still has all lights going crazy and isn't synced with my virtualDJ
geposted Sun 28 Aug 16 @ 4:41 pm
See post #2. Also please give details of your setup. Mac/PC? Operating System?
geposted Sun 28 Aug 16 @ 5:16 pm
Numark Mixtrack, running on a macbook pro 2015 w normal specs
geposted Sat 03 Sep 16 @ 9:10 pm
geposted Fri 09 Sep 16 @ 2:13 am
