Hi all.
I seem to have a slight issue. Its bearable when playing at home but when playing out, i cant have this issue.
i could be playing for a while the out of no where i get a error message saying loss of time code signal. the only way to recover is to shut down and re launch VJD
I am using a dedicated laptop optimized for dj'ing only. business model del. i5cpu 8GB ram & a SSD. running windows 7.
i have a DVS Native Instruments A6 sound card using Traktor scratch MK2 vinyl on 2x stanton str-8 turntables. Using standard needles. I also have serato vinyl that does the same thing.
when using straight up " real " vinyl i dont have any problems. only seems to be when i use a DVS. Any help would be appreciated..
keep spinnin!!!
keep spinnin!!!
geposted Sat 18 Jun 16 @ 12:11 pm
Have you tried swapping USB cables?
If you go to the timecode settings, is anything showing during testing?
Do you use the external power supply for the Audio 6
I'm leaning towards VDJ losing connection to the sound card.
I've been using the Audio 6 with my kit for years. The only time I've had a similar issue was because the USB cable was loose.
geposted Sun 19 Jun 16 @ 1:13 am
have changed USB cables... no success.. no not using power with time code. should i ? yep external mixer Pioneer DJM3000
geposted Sun 19 Jun 16 @ 8:06 am
If there is a lot of draw on your USB bus, like external drives, you may want to try an external power supply or a good powered hub.
I carry my timecode gear pre wired in a coffin case. I have had a weak signal issue when an rca cable came loose. I unplugged it and reconnected it, but did not have to restart VDJ.
How strong is the signal in the timecode calibration area in confiig?
geposted Sun 19 Jun 16 @ 4:44 pm
Please help I'm having the same problem and I have a gig tonight, using CDj 1000s with a djm 350 with the Maya 44+ USB interface on Mac OS X sierre, I am also using virtual Djs downloaded time code CDs . When calibirating I get good speed and signal but then five mins in I get an error messaging saying it's not calibrated, I then have close the application before I can get control again
geposted Fri 18 Nov 16 @ 2:56 pm
http://www.virtualdj.com/download/build.html
previous builds try one of these
geposted Fri 18 Nov 16 @ 4:41 pm
