Forum: Addons
Topic: The Thing - Page: 7
GalawasPRO InfinityMember since 2013
geposted Tue 18 Sep 18 @ 8:26 pm
Another way to work around. Thanks for sharing this info.
geposted Tue 18 Sep 18 @ 8:27 pm
Hello.. I installed the latest skin update with latest VDJ and it is showing a floating browser window. I don't know how to close it.
This never showed up on the last skin. I even downgraded to 4514 and that did not change anything.
Thanks for any help in advance.
LJ
geposted Tue 18 Sep 18 @ 8:47 pm
Just rightcklick on the zoom in the top-bar
The floating browser ist for the user with 2 monitors ;o)
geposted Tue 18 Sep 18 @ 8:50 pm
Thank you.. that worked!
geposted Wed 19 Sep 18 @ 5:45 pm
djnet71PRO InfinityMember since 2007
It seems that the issue with the marks on the waveforms was fixed with the 4580 version of VDJ.
iI try it for a while and it seems ok...
anyone else's feedback?
geposted Thu 20 Sep 18 @ 11:40 am
Ok!New issue with 4580 version?
Since the previous versions...everything was written in TagEditor/Remix (getting it from title) was showed twice on deck info so everytime i add a track with parenthesis for example : (john's edit) i used to get in tag editor ande delete the remix content.
Now with 4580 version there is no need to do that because on deck info it shows once the contetn of remix field!
But...all my tracks that i have delete the content of remix field now with the 4580 version not show the remix field on deck info so i can't see if it is a remix or not!!!
Any ideas how to fix/work on this???
geposted Thu 20 Sep 18 @ 12:31 pm
I'm at work, will take a look this late afternoon.
geposted Thu 20 Sep 18 @ 1:21 pm
Ok,thanx!
May be i have to change something in the options in tags or in remix?
we'll see
geposted Thu 20 Sep 18 @ 1:28 pm
I make some changes at the options...1.TAG & 2.Remix and now worked as it was before....but iam sure that something changed with the latest early access 4580 and had to change some options.If anyone has the same problem with the remix field on the deck info...let me know to upload photos of my settings in options : 1. tag & 2.remix to check.
Thank you music234 for your quick reply!
geposted Thu 20 Sep 18 @ 1:56 pm
Seems to be fine right here...
Please check these Options:
geposted Thu 20 Sep 18 @ 3:41 pm
@all Users of The Thing:
The issues with the marks on the waveforms were fixed with the 4580.
Please update VDJ to the last build.
geposted Thu 20 Sep 18 @ 8:37 pm
Unfortunately the ''headquarter'' pull down the last update 4580 because of a bug with input tracks in virtualfolders(for some users).
So the last one is 4537 with the issue in THE THING skin and we are looking forward for the next (bugless) update with no bars at the wave forms!!!!
geposted Tue 25 Sep 18 @ 11:34 pm
Damm!
....but there is nothing I can do about it.
Sorry.
geposted Wed 26 Sep 18 @ 6:06 am
music234 wrote :
Damm!
Sorry.
I know!
Let’s hope that they’ll release soon a new update and THE THING issue will fixed there
geposted Wed 26 Sep 18 @ 6:25 am
New early access 4591 is out and THE THING skin works great again!!!!
geposted Thu 27 Sep 18 @ 4:00 pm
Jupp.... as mentioned: good thing(s) take a while ;o)
geposted Thu 27 Sep 18 @ 6:20 pm
working on another update.... just a progress (some sampler features missing at the moment) and will take a while to finish:
Stay tuned ;o)
geposted Fri 28 Sep 18 @ 4:52 am
djnoaiPRO (legacy)Member since 2017
Since the new version 4591, the track info behind the title no longer shows the remix information (in parentheses).
In the previous version 4537 it was still correct with TheThing.
The default skin is still correct for both versions.
Is this a problem of the vdjversion or of the skin?
geposted Fri 28 Sep 18 @ 9:03 pm
84%
