Topic: Lock All Cues
hrdnxPRO InfinityMember since 2011
Hi All
Is there a way to lock all cues???
geposted Tue 21 Jun 16 @ 9:53 pm
All cues of all songs ? Or all cues of a single song ?
geposted Tue 21 Jun 16 @ 9:57 pm
All cues
to prevent accidental deletion by me or someone else using my PC
it can be done per song presently
and i can map this to a button .........lock_cues
geposted Tue 21 Jun 16 @ 11:03 pm
lincol2PRO InfinityMember since 2011
geposted Wed 22 Jun 16 @ 1:31 am
Ok follow these instructions
1 back up your database
2 open your database with a text editor and press Ctrl+H, (AKA edit>find&replace or edit>replace)
3Find
<Infos
Replace with
<Infos LockedCues="1"
Replace all
4 Save
That's it......
geposted Wed 22 Jun 16 @ 4:26 am
Yep that could work, but if i want to turn it off again
Was thinking this could be included in the options menu, so at home i could turn it off and then on again before a gig
geposted Wed 22 Jun 16 @ 11:34 am
As an alternative you can set your database to "readOnly" mode via settings.
Changing the "readOnly" setting requires a restart of VirtualDj to work, but ANYTHING you do while "readOnly" mode is active does not save on database (Playcount and last played dates don't change, poi changes do not save bpm scan does not save e.t.c.)
geposted Wed 22 Jun 16 @ 12:36 pm
