Hello everyone.
I work as a DJ in weddings and birthdays, in which music'm mixing approximately 8 hours.
In recent times about 5 hours going after music, song stumbles as if automatically make a loop of 1/32 and for a few seconds the virtual dj not answer me.
In most of the time I pass a few seconds (because I put music on my other notebook backup) and then the VDJ works well.
I happening very often and need to fix it. Could you help me??.
My notebook is MacBook Pro (Retina, 15-inch, Mid 2014) with the system os x El Capitan 10.11.5, 2.2 GHz processor Intel Core i7, 16GB DDR3 1600 MHz.
I use mac version 8.1 build 2857,116.
I use WD external hard drive 1TB (external disk change because I thought that this was the problem, I bought a new one and the problem persists).
Pionner console Sz
(I made a notebook formatting and install everything again and the problem persists)
- I have license virtual dj, the technical support told me that the usb ports may be put at rest, which I think is rare).
I appreciate if I can help.
regards
SPANISH...
Hola a todos.
Yo trabajo como dj en boldas y cumpleaños, en las cuales estoy mezclando musica aproximadamente 8 horas.
En las ultimas veces aproximadamente luego de 5 horas pasando musica, se tranca la cancion como si se hiciera automaticamente un loop de 1/32 y por unos cuantos segundos el virtual dj no me responde.
En la mayoria de las veces dejo pasar unos segundos ( porque pongo musica en mi otra notebook de respaldo ) y luego el VDJ funciona bien.
Me esta sucediendo muy seguido y necesito solucionarlo. Me podrian ayudar??.
Mi notebook es MacBook Pro (Retina, 15-inch, Mid 2014) con el sistema os x El Capitan 10.11.5 , procesador 2,2 GHz Intel Core i7, 16 GB 1600 MHz DDR3.
Utilizo la version 8.1 mac build 2857.116 .
Utilizo disco duro externo WD de 1tb ( cambie de disco externo porque pense que este era el problema, me compre uno nuevo y el problema persiste).
Consola Pionner Sz
(Hice un formateo de la notebook e instale todo de nuevo y el problema persiste)
- Tengo la licencia del virtual dj, los del soporte tecnico me dijeron que los puertos usb tal vez se pongan en reposo, lo cual me parece raro).
Agradezco si me pueden ayudar.
Saludos
Pionner console Sz
regards
SPANISH...
Hola a todos.
Consola Pionner Sz
Saludos
geposted Wed 22 Jun 16 @ 4:19 am
You should also check:
1) Your laptop is not overheating
2) Your external hard drive does not go to sleep after some time of inactivity
3) USB ports are not doing power saving
geposted Wed 22 Jun 16 @ 12:51 pm
I check that, and the notebook does not heat, I set the usb never put into sleep mode.
geposted Fri 23 Sep 16 @ 11:04 pm
Why not try 8.2?
geposted Fri 23 Sep 16 @ 11:23 pm
Pioneer SZ on a Mac. I suggest you should try increasing the audio latency.
There has recently been a thread about sound problems with the SZ on Macs, and the solution was as above.
geposted Sat 24 Sep 16 @ 9:09 am
The funny thing is that I did not happen before. Suddenly I began to work.
With windows I haven't problems.
geposted Mon 03 Oct 16 @ 4:25 am
