Topic: Bug with sideview skin beacon
Found something buggy with the <sideview/> skin beacon. It will always show the sampler.
Steps to reproduce :
1 - Open VDJ (lol)
2 - Load a song and play in deck 1
At this time the sideview works flawlessly
3 - Minimize VDJ then un-minimize it
Now the sideview will only show the sampler no matter what tab you select. I use win7.
geposted Tue 28 Jun 16 @ 3:57 pm
To me on W10 it shows the set panel before minimize
I Use default skin
The default skin does not have any <sideview/> element but thanks anyways.
I noticed I can't reproduce it @ home in 2 of my computers (Win7 as well). Only @ work. The difference I can point at for now is that at work I run the FREE version, and at home the paid full VDJ.
FRUiT remember that the free version is 8.1 not 8.2
I tried to replicate on a windows 7 PC where i have 8.2 eith your skin and i don't see thr issue. I also tried different skins and even the default one...must be something else.
OFC there's a free 8.2 version, I download it with my account but then I can't log in because of the proxy server.
Ok I could reproduce it at home too, and with paid version.
In the <sideview/>, the trigger-pads view must be selected. Then if you minimize, reshow the window, the bug appears, can reproduce everytime.
Also another bug found :
When I click on the 'trigger-pads' button inside the <sideview/> it will show the pads in the browser but not in the sideview. Once I minimised and un-minimized the window, the pads will show in the sideview, but/and nothing else.
As you can see the automix panel is selected in the sideview, thus the sampler is still in front of it.
Issue still not solved in 3343.
Issue still not solved in 3471.
I can't reproduce this. What happens if you do a fresh install?
Edit Irrelevant, disregard
Are you using FRUiT's skin?
It's an issue when using "custom" browser elements, not with the default browser used in most skins. It's been broken since the release of 8.
Got it.
