Forum: VirtualDJ 8.1 Technical Support
Topic: Tab not switching PFL (headphones)
Hi all,
For some reason sometimes the usual behavior of TAB - i.e. switch the active deck + activate PFL on new deck + deactivate PFL on old deck - stops working.
I've noticed this happens usually after I use the POI editor.
After that, when I press TAB the active deck changes but the PFL is only turned on for the left deck when switching to it and it's never turned off + the right deck's PFL doesn't change at all (if it's on it stays on, and if it's off it stays off).
This is solved when I close VDJ and reopen it, or if I switch to a VDJ 7 skin.
I tried changing the autoHeadphones and pflOnSelect options but it didn't solve it.
Has anyone else encountered this? Do you have any solution?
I don't want to have to restart VDJ in the middle of a set...
Thanks!
geposted Wed 29 Jun 16 @ 4:41 am
I wonder if it has something to do with the fact that you are in the POI editor? Something along the line of, since it is open, the PFL script can't execute to switch the buttons.
I think it is triggered by using the POI editor but it happens after I close it as well so I don't think it's just a matter of it not running some background process.
