Forum: Addons
Topic: Reloop Terminal Mix 2 - Enhanced VDJ 8-Mapping
Discussion about Reloop Terminal Mix 2 - Enhanced VDJ 8-Mapping
Range: Pitch Bend + (2% 500ms)Range + Shift: Pitch ResetKeylock: Pitch Bend - (2% 500ms)Keylock + Shift: Key LockButton FX 1: Echo Doppler activeSlider FX 1: Slider 1Slider FX 1 + Shift: Slider 2Button FX 1 + Shift: Video Effect "Boom Auto"Button FX 1 + Layer: Effect "Beat Grid" active while pressedButton FX 2: FlangerHQ activeSlider FX 2: Slider 1Slider FX 2 + Shift: Slider 2Button FX 2 + Shift: Video Effect "Spectral"Button FX 2 + Layer: Effect "Backspin" Button FX 3: FlangerHQ activeSlider FX 3: Slider 1Slider FX 3 + Shift: Slider 2Button FX 3 + Shift: Video Effect "Strobe Auto"Button FX 3 + Layer: Effect "Brake Start" Loop Half: Loop InLoop Half + Shift: Key -1Loop Double: Loop OutLoop Double + Shift: Key +1Sampler 1 Left Deck: Pad 1 from Sampler-Bank "FAMOUS"Sampler 2 Left Deck: Pad 2 from Sampler-Bank "FAMOUS"Sampler 3 Left Deck: Pad 3 from Sampler-Bank "FAMOUS"Sampler 4 Left Deck: Pad 4 from Sampler-Bank "FAMOUS"Sampler 1 Right Deck: Pad 5 from Sampler-Bank "FAMOUS"Sampler 2 Right Deck: Pad 6 from Sampler-Bank "FAMOUS"Sampler 3 Right Deck: Pad 7 from Sampler-Bank "FAMOUS"Sampler 4 Right Deck: Pad 8 from Sampler-Bank "FAMOUS"Sampler 5 Left Deck: Pad 1 from Sampler-Bank "VIDEO & SCRATCH"Sampler 6 Left Deck: Pad 2 from Sampler-Bank "VIDEO & SCRATCH"Sampler 7 Left Deck: Pad 3 from Sampler-Bank "VIDEO & SCRATCH"Sampler 8 Left Deck: Pad 4 from Sampler-Bank "VIDEO & SCRATCH"Sampler 5 Right Deck: Pad 5 from Sampler-Bank "VIDEO & SCRATCH"Sampler 6 Right Deck: Pad 6 from Sampler-Bank "VIDEO & SCRATCH"Sampler 7 Right Deck: Pad 7 from Sampler-Bank "VIDEO & SCRATCH"Sampler 8 Right Deck: Pad 8 from Sampler-Bank "VIDEO & SCRATCH"Sampler 1 Left Deck + Shift: Pad 1 from Sampler-Bank "INSTRUMENTS"Sampler 2 Left Deck + Shift: Pad 2 from Sampler-Bank "INSTRUMENTS"Sampler 3 Left Deck + Shift: Pad 3 from Sampler-Bank "INSTRUMENTS"Sampler 4 Left Deck + Shift: Pad 4 from Sampler-Bank "INSTRUMENTS"Sampler 1 Right Deck + Shift: Pad 5 from Sampler-Bank "INSTRUMENTS"Sampler 2 Right Deck + Shift: Pad 6 from Sampler-Bank "INSTRUMENTS"Sampler 3 Right Deck + Shift: Pad 7 from Sampler-Bank "INSTRUMENTS"Sampler 4 Right Deck + Shift: Pad 8 from Sampler-Bank "INSTRUMENTS"Sampler-Volume-Slider: Video-CrossfaderGain-Slider Left-Deck: Sampler-Volume Sampler-Bank "FAMOUS"Gain-Slider Right-Deck: Sampler-Volume Sampler-Bank "VIDEO & SCRATCH"Gain + Shift: "normal" Gain-SliderFilter-Slider: Effect "Filters_v2_TexZK"Crates-Button: Function "Brower_Folder" (With Focus on the Titles, it changes to Folderlist, with Focus on Foders, Subfolders will open)View-Button: Shows Effect-GUIBack-Button: Jumps back between the Browser-WindowsBack-Button + Shift: Jumps back in the SideviewPrep-Button: Jumps forward between the Browser-WindowsPrep-Button + Shift: Jumps forward in the SideviewPlay-Button: Play/Pause, but when holding 1 Second while deck is not playing, Track goes to Playtime 00:00Play-Button + Shift: Play/Pause, but when holding 1 Second while deck is not playing, Track goes to Hotcue 1
geposted Wed 29 Jun 16 @ 7:41 pm
Loop Half: Loop In
geposted Thu 30 Jun 16 @ 2:46 pm
Changes in Version 1.1:
- Changed FX3 to "LoopOut" (not SBDJ's Version !)
- All FX-Buttons set to fixed Slider-Parameters
- Fixed some issues with the Layer-Button (incl. difference between right and left deck)
- Loop Length-Button + Layer: Key 0
- Changed "View"-Button to "Video-Transition" with a duration of 6 seconds
- OnInit is set to VDJ-Headphone-Volume=50%
- Changed functions of the Gain-Slider:
- Gain-Slider Left-Deck: Software Master-Volume
- Gain-Slider Right-Deck: Software Balance
- Gain-Slider + Shift: "normal" Gain-Slider
- Gain-Slider Left-Deck + Layer: Sampler-Volume Sampler-Bank "FAMOUS"
- Gain-Slider Right-Deck + Layer: Sampler-Volume Sampler-Bank "VIDEO & SCRATCH"
Needed Downloads:
Loop Out: http://http://www.virtualdj.com/addons/581/LoopOut.html
geposted Mon 26 Sep 16 @ 10:36 am
Changes in Version 1.2:
Fixed an issue with pitch-bending
geposted Wed 05 Oct 16 @ 7:31 am
