Topic: numark nv 2
hh73PRO InfinityMember since 2006
will the numark nv 2, the one just out. work as well with vdj as the original numark nv?
geposted Thu 30 Jun 16 @ 11:41 am
The NV2 is not yet supported.
geposted Thu 30 Jun 16 @ 4:25 pm
Bonjour, Quand sera pris en charge le NVII par Virtual Dj ? Merci
geposted Sat 27 Aug 16 @ 7:23 pm
S'il vous plait essayer notre forum francais ici, je vous remercie.
geposted Sun 28 Aug 16 @ 1:53 am
geposted Mon 05 Sep 16 @ 3:17 pm
geposted Wed 07 Sep 16 @ 9:31 am
djx057Home userMember since 2014
I can't get my NVII to work with virtual DJ8. IS it compatible or is it something on my end?
geposted Wed 28 Sep 16 @ 10:08 pm
geposted Wed 28 Sep 16 @ 11:14 pm
Is there an ETA on NV2 support? My NV just bit the dust after a bar fight spilled crap all over it. If I'm gonna buy a new controller, I'd rather get the NV2.
geposted Sun 16 Oct 16 @ 5:10 am
if u can afford it get the denon mc6000mk2. its small but sounds great and is mapped for every program. i just got the mcx8000 with screens. its big. like a pro nv2. works a charm. and keep punters away from you :)
geposted Sun 16 Oct 16 @ 9:49 am
It's on the "coming soon" list:
http://virtualdj.com/wiki/VirtualDJ8%20Controllers.html
So with any luck my guess would be that it's supported before you can get your new NV2
But there are no guarantees
geposted Sun 16 Oct 16 @ 11:45 am
NVII support will be included in the next Early Access build, hopefully in a week or so. Tested and running flawlessly, so if you guys plan to buy one, you have the green light from Atomix.
geposted Sun 16 Oct 16 @ 11:50 am
I hate it when you guys immediately top my guessing posts with actual knowledge :)
geposted Sun 16 Oct 16 @ 11:51 am
