Forum: VirtualDJ 8.1 Technical Support
Topic: Black-Waves Problem !?
Im using Vdj for a few months ago, it was great, everything is okay..
Once, i downgraded my windows from 10 to 8.1, i got a problem in Vdj app,
Its working fine but i shows a quick black-waves a lot of times like every second.
Pls help me to solve this problem, Thanks!
geposted Thu 30 Jun 16 @ 3:57 pm
geposted Thu 30 Jun 16 @ 11:04 pm
CannenPRO InfinityMember since 2016
I noticed that sometimes that happens with really long songs or ones that weren't encoded to MP3 correctly. Check and see if it does it only on certain songs or lengths.
geposted Thu 30 Jun 16 @ 11:17 pm
I'm gonna say it might be video drivers. Install an 8.1 version instead of the win 10 version.
geposted Fri 01 Jul 16 @ 1:20 am
Bro i fully formatted my pc before downgrading the windows, so i don't think that's my issue.
and it happen even when i don't play any song, once i open the app the problem starts... :/
geposted Fri 01 Jul 16 @ 1:22 am
i think when i use more apps at the same time with VDJ the waves abound..
guys pls help me
geposted Fri 01 Jul 16 @ 1:40 am
What are the specs on your computer? RAM, Processor, Video Card, OS?
geposted Fri 01 Jul 16 @ 3:23 am
Ram: 6Go
Processor: Intel Core i5
Video Card: Nvidia Geforce 840M
Windows 8.1
http://i.imgur.com/dn1rtcL.png
i think some people dream to get these specs
but about two days the app was alright i don't know what happened
geposted Fri 01 Jul 16 @ 2:18 pm
Am still looking for a solution pls
geposted Mon 04 Jul 16 @ 3:16 pm
I'm not sure what would cause that, I've never seen it before. As above, I'd check your video drivers - have a look in Device Manager to check it's installed correctly.
If it was working fine before you reinstalled windows then that would suggest it's something to do with your windows installation.
geposted Mon 04 Jul 16 @ 3:22 pm
Am back here just to tell you that my problem is solved after updating my Nvidia Gefoce and Intel HD graphics cards, Thank God and you for helping me or trying to help me! :)
And next time if someone had this problem just tell him "Update Your Graphics Card(s)", Thanks again and bye lemme enjoy my VDJ! :D
geposted Thu 14 Jul 16 @ 9:26 pm
