Topic: Can I use Advanced Home version on different computers but same controller?
DDappaControlleristMember since 2016
I bought a Denon MC4000 and I a thinking about trying Virtual DJ with it. I have two PC's and would like to be able to use either of the two PC's with the one controller... Is that possible if I make a one time purchase for the "Advanced Homer User" controller specific version?
geposted Fri 01 Jul 16 @ 1:02 am
Yes, the Plus license (Advanced Home) will unlock your controller to any computer you install VirtualDJ and login with your account credentials.
geposted Fri 01 Jul 16 @ 3:12 am
Thank you for that. But then does that mean I need to have internet access each time to log in? For example if I'm at my parents' where there's no internet....?
geposted Sun 03 Jul 16 @ 3:29 am
Discussed many times, at length.
tldr version;
If there is no internet access then a logged in machine will stay logged in.
geposted Sun 03 Jul 16 @ 3:55 am
Here's the indepth info
link.
geposted Sun 03 Jul 16 @ 7:31 am
