hello, I have a serious problem with the skin of tcmania installed on virtual pro 8, the problem is that the window only appears rhythm rhythm of the blue deck, the rest - yellow, red, green does not appear. if you charge them a song on the deck. however if you load a theme in blue deck (being master) on the other deck if the pace is displayed. then you get the theme of the blue deck and another rhythm disappears, only shows the blue the rest do not work, I've tried all the possibilities that could fix it believed was perfect .I need to see before reading the 4 decks, above and only appears one to read. as I can fix it and leave it fixed as I always have had
geposted Sun 03 Jul 16 @ 6:46 pm
