Topic: Hot Cue Number 1 not lighting up
I'm using 8.2 pc build 3286.1170 and I've just noticed that the pad for hot cue number 1 is not lighting up on the skin or on my ddj sp1. The cue point is still there and is activated as normal when I press or click the appropriate pad. This problem was not present in the early access mode so I was wondering if it's an issue with the current public build. Anyone else had this happen?
geposted Tue 05 Jul 16 @ 8:35 pm
Problem solved!! I forgot to mention that I experimented with some custom pads and I think I must have done something wrong. I have just pressed 'reset page' in the pads editor screen and everything is fine once more.
geposted Tue 05 Jul 16 @ 8:54 pm
