When using the Time Left display mode on the pad buttons, the font is really, REALLY small. My aging eyes are having trouble making out the numbers. Any way to make the font larger on these buttons? I'm using the VDJ8 default 2 decks interface. Thanks!
geposted Wed 06 Jul 16 @ 9:42 pm
You can change the font size in the Skin's XML config file. It will be located under Textzones of the Hotcue Pads.
Jon J
Jon J
geposted Wed 06 Jul 16 @ 11:20 pm
Thank you TJ! Amazing how much difference going from 14pt to 20pt can make.
Jon J
Jon J
geposted Wed 13 Jul 16 @ 9:25 pm
You are welcome.
geposted Thu 14 Jul 16 @ 1:54 am
