Just got the upgrade and start playing around with it today and notice:
I have a DDJ SR with the VDJ 8.2 upgrade working but since the upgrade my 2 of my 3 effects buttons no longer work properly. The first button when pushed, the effects will light up and will work. When FX 2 or FX 3 buttons are pressed, it changes the effect on the FX 1 button. Wasn't doing this before the upgrade. Is there a fix for this or is there something that needs to be changed on the SR for this to work properly again?
Thanks,
TK
Thanks,
TK
geposted Thu 07 Jul 16 @ 12:07 am
SHIFT+TAP toggles between the Multi Effects mode (probably theone you want) and the Single Effects mode.
Read more here..
http://www.virtualdj.com/documents/Pioneer%20DDJ-SR%20VirtualDJ%208%20Operation%20Guide%20v.2.pdf
page 9
Read more here..
page 9
geposted Thu 07 Jul 16 @ 12:44 am
Worked like a charm
geposted Thu 07 Jul 16 @ 11:21 am
Thank you so much djdad!!!
geposted Wed 13 Jul 16 @ 10:10 pm
