Forum: VirtualDJ 8.1 Technical Support
Topic: Mapping DDJ SX1
Hello everyone
Ihave a Little Problem with the mapping.
I changed the Pad from Slicer to Autoloop with 1/2, 1, 2, 4, 8 and so on.
Now, the LEDS are still changing with the beat, like with the slicer-mode.
Thats not good.
I found die LED-Slicer-Pads in the mapping, but what is the correct order, to have only the pad on, which i selected?
if it is flashing , or is just on would be uninteressting.
I hope, someone could help me.
bye
geposted Thu 07 Jul 16 @ 11:00 am
If its the DDJ-SX (not the SX2 with the RGB Leds) then simply delete the assigned actions from those LED_SLICER_PADs keys.
If this doesnt work, you will need to assign the same action as you did with the PADs so .e.g loop 1, loop 0.5 etc
BTW, if you update to version 8.2, the default mapping controls the new Pads section of the default skins, and all you would have to do in order to change a mode from Slicer to anything else (e.g. auto Loops), would be to change the Pad page name from the action of the PAD mode button.
geposted Thu 07 Jul 16 @ 1:45 pm
Sorry, i didn't understand.
Would you give me the correct command please.
This is what i have and this is not correct
var_equal 'padmode' 2 ? slicer 1
Perfect would be the same like "samples".
YES, i have DDJ SX1, only the blue LEDs
geposted Thu 07 Jul 16 @ 3:59 pm
As above for the LEDS , you need to .. either delete the action completely or use the same action like you had in the PAD
Example :
SLICER_PAD_1 : loop 0.5
LED_SLICER_PAD_1 : loop 0.5 (or nothing - empty)
geposted Thu 07 Jul 16 @ 10:38 pm
it was sooooo easy
thanks!!!
Last question
what is the command for every 8 leds are still on and the pad i select is flashing
geposted Fri 08 Jul 16 @ 1:36 pm
loop 0.5 ? blink 500ms : on
you can use different value in ms to make it blink faster or slower.. 500ms will blink every half second
geposted Fri 08 Jul 16 @ 2:09 pm
