Topic: Problems with ddj-sb2 after update
Since i updated to the new firmware earlier this afternoon, the majority of the left side pads have stopped working on my pioneer DDJ-SB2
everything else is working the same as before and even the right side pads work fine its just the left ones, anyone know any solutions to this?
Thanks very much
EDIT
I have also done a fresh install of my controller drivers and a fresh install of VDJ with no luck
geposted Thu 07 Jul 16 @ 4:01 pm
Can you please provide further details on which Pads dont work and on which modes ?
Are you using the factory default mapping ? If not, can you try with that ?
Also, try this...
assign the SHIFT buttons as ..
shift
delete the entire action you will see in there and just use the above verb (will create a new custom mapping) and try again to see if all Pads work now
thanks
geposted Thu 07 Jul 16 @ 4:33 pm
