Topic: Logo on ask the dj
I chose the wrong logo when adding a logo to ask the dj is there a way to change this
geposted Fri 08 Jul 16 @ 3:18 pm
Simply go back into the setup screen and choose the venue. In the logo options, you can re-upload a new logo where it says "choose file"
I've posted on this thread as it is related to the topic (which I hope is ok) - is there a maximum size, or specific size setting for the logo?
Thanks
Maximum filesize should be around 2MB.
Images will be resized automatically to fit in the provided area.
the refit rezie does not work on my logo as this was in landscape !!!!
nice featurt ask the dj... its going to get some use
If your logo is e.g. 500x100, try to re-create that and export to 500x500 (by adding a transparent background 500x500)
Thanks for the info @djdad
MR DJ NEED A SONG BY CHEF 187 NEW
