Why are the Settings and the Tag Editor windows no longer "click and drag" in 8.2? I would like to simultaneously use them while DJing too! But I am unable to temporarily move them out of the way, instead of having to close and reopen! When I am writing VDJscript or custom skins, at home I use a multi screen setup with my laptop. Its very irritating to not be able to move the windows around!
geposted Tue 12 Jul 16 @ 7:43 am
what build and os are you using - it works here 3291 windows
geposted Tue 12 Jul 16 @ 8:06 am
I don't mean to hijack, but is there a reason that they won't remain full screen after I put them that way?
geposted Tue 12 Jul 16 @ 8:10 am
Make sure videoForceFullScreen is set to 0 if you want to move the editors around and use them at the same time.
I believe it's already in the wishes forum to remember the size of the windows.
geposted Tue 12 Jul 16 @ 9:26 am
