After upgrading to VDJ 8.2 everything so far seems to be OK except my effects tabs-- hot cue, slicer etc work on the screen but not on the controller. If I push slicer the screen doesn't recognize it. If I mouse over it and click it all of the tabs work. It worked before the upgrade. As I mentioned, everything other than that seems to be working. Suggestions?
geposted Tue 19 Jul 16 @ 11:29 pm
I assume you are using a Custom mapping. In order the Pads to be controlled and changed from your controller, you will have to modify your custom mapping or use the factory default
geposted Wed 20 Jul 16 @ 12:17 am
Thanks. Is there a tutorial you can point me to to for installing the latest mapper.
geposted Wed 20 Jul 16 @ 11:52 am
The latest factory default mapping is included in the software. You will have to select it from VirtualDJ Settings->CONTROLLERS tab.
Click to select the DDJ-SX2 and then from the right side choose the Factory default from the Mapping list.
geposted Wed 20 Jul 16 @ 12:15 pm
Thanks DJDad, you're the greatest...one follow up question though. When you say native do all of the features on the SX2 work or are some of the features still not available.--Thanks.
geposted Thu 21 Jul 16 @ 3:11 am
