Topic: Video
AsTheDJPRO InfinityMember since 2008
The video window kept popping up after 10-15min when I was doing a gig( friday & sat ) I had to change skin from the new VDj-8.2 to SBDj to stop it.
geposted Sun 24 Jul 16 @ 9:25 pm
go into options and see if StartVideoOnLoad is enabled?
geposted Sun 24 Jul 16 @ 11:14 pm
It's ck No so ck Yes so the video window Don't pop up? I don't Play videos any more.
geposted Mon 25 Jul 16 @ 1:13 am
if you don't want videos to load it should be checked No. the video will still load on the deck but the window shouldn't open
geposted Mon 25 Jul 16 @ 1:36 am
Map a custom button to
video_output 'off' (or videoOutput 'off', you have to try, I'm not sure ATM)
geposted Mon 25 Jul 16 @ 10:33 am
I will look over my mapper it just started doing that after the last update,some of the new updates don't work well with mapper with VDj-8.0-0.1 skins after VDj updates,4me
geposted Mon 25 Jul 16 @ 5:39 pm
