Topic: How to setup Pioneer DDJ2000NXS2 with VDJ8
I am out of town and have been give two Pioneer DDJ2000NXS2 Controller. My Imac recoginses the two controller and in settings they show up but I can seem to get one to go to channels 1 & 2, and the second to go to channels 3 & 4.
Both want to map to channels 1 & 2, or channel 1 or 2 individually as mono.
HELP! I have about 2 hours to figure this out.
Thanks!
geposted Sun 24 Jul 16 @ 11:40 pm
geposted Sun 24 Jul 16 @ 11:57 pm
I'll watch the video, but I changed the setup the to use two usb's. it sees two controllers but nothing works. Both want to go to channels 1 & 2. or induvidually to 1 or 2. Still nothing works.
geposted Mon 25 Jul 16 @ 12:02 am
each cdj only has 2 channels in its sound card so yes all u will see is 1 and 2 in the setup :-)
so channel 1 and 2 on both should be correct
geposted Mon 25 Jul 16 @ 12:07 am
no, that way its mono. Besides, it still did not work. I think what someone else said is true that Virtual does not support 2000NXS2.
I am ready to give up and not use the controller.
geposted Mon 25 Jul 16 @ 12:40 am
You should have one line 'deck 1' and one line 'deck 2' in the audio config.
When you open the sound card drop down, you should see the cdj2000nxs2 listed 2 times.
Make sure the deck 1 line has the top one selected, and deck 2 line has the bottom one selected. Then each uses channel 1&2 (stereo)
geposted Mon 25 Jul 16 @ 6:54 am
