Topic: Pitch Match Range - Too Much
If I have a track loaded in player A that has a BPM of 100 and I have another track loaded into player B with a BPM of 80 and I accidentally hit the "sync" button to match the tracks. What can prevent the trainwreck of player A instantly slowing down to 80 BPM the moment I hit the button?
I have my pitch range at 10 but every time I hit the button, the tracks slow down.
I do not want them to match pitch if they are beyond the 10% that I have selected.
geposted Mon 25 Jul 16 @ 2:38 am
Disable the option 'autoPitchRange' or don't hit sync :p
geposted Mon 25 Jul 16 @ 9:08 am
You should also make sure that the track you are playing are the master track by selecting it in right top corner of the deck.
geposted Mon 25 Jul 16 @ 1:25 pm
Huh?
geposted Mon 25 Jul 16 @ 5:05 pm
Huh?
There is always a master deck. Just check. If you select the track that is playing to be the master deck, other decks will follow the master decks BPM if you hit sync-button.
geposted Mon 25 Jul 16 @ 5:38 pm
locodogPRO InfinityModeratorMember since 2013
Un-needed, just follow this advice.
geposted Mon 25 Jul 16 @ 5:53 pm
[/quote]
I see your point. With the master deck checked, you will not get suddenly drops if track B is 9% of the deck A's pitch either... but sure, should not hit sync button unless you want to...
geposted Mon 25 Jul 16 @ 7:17 pm
Perfect! Thanks again!
geposted Mon 25 Jul 16 @ 7:52 pm
