Topic: Can't get timecode vinyl to work with VDJ.
itekdjPRO InfinityMember since 2016
Hi guys, I'm using latest version of VDJ, Trying for the first time to work with Vinyls...
I'm using Traktor Audio 6 as sound card, and Traktor timecode vinyl.
I connected everything in the right way, installed the sound card driver, but... when I try to calibrate it says "The signal is not stereo. You need to connect your turntable to a stereo input for timecode to work".
I can hear the time code noise coming out of my mixer... So signal is sending.
Also, in the Audio settings, on Card tab, I my sound card won't show...
Any idea how to make it work?
geposted Mon 25 Jul 16 @ 5:17 pm
That's your main issue.
Please make sure that you have installed the LATEST ASIO drivers provided for your soundcard by Native Instruments
geposted Tue 26 Jul 16 @ 5:03 pm
