Topic: Mapping browser for Pioneer DDJ controller
djtompicControlleristMember since 2016
I am using the MULTI TouchScreen skin and can't find the codes for the main Browser button (switch views) and for the Browser Tabs for switching folder views (folder tree|folder|automix|info). Can anyone here post the codes? Thanks much.
geposted Tue 26 Jul 16 @ 1:06 pm
locodogPRO InfinityModeratorMember since 2013
skin_panelgroup 'views' +1
show_splitpanel 'folders'
show_splitpanel 'automix'
show_splitpanel 'info'
geposted Tue 26 Jul 16 @ 4:08 pm
Thanks locodog. Awesome info! This is exactly the codes I needed.
I had to make a slight change for the automix tab to work. In case anyone else uses these, the one for automix panel tab should be:
show_splitpanel 'sideview'
geposted Wed 27 Jul 16 @ 6:58 pm
