Topic: vdj 8.2 mac osx 10.7.5
just gave a try to vdj 8.2.3 and I'm having issues in the config windows, text gets blurred when scrolling options window,
I'm on OSX 10.7.5, will this os still have support?
thank you
geposted Tue 26 Jul 16 @ 9:35 pm
I see some updates on mac, would dev team be kind and please check the issues on osx 10.7
thank you
geposted Mon 24 Oct 16 @ 11:53 pm
menu window get blurred when scrolling up/down,and scratchwaves dont show up in mac osx 10.7.5 ,
please work on this issues
thank you
geposted Wed 26 Oct 16 @ 4:36 pm
just tried an updated vdj my old macbook (C2duo 2.2ghz 2007), and the sratchwaves were fixed back on build 3790 (2017-06-28)
"-Fix scratch wave calculation on old processors",
thank you, my macbook is always a great backup machine
the text still gets blurred in the window config,( I know what to search and what to type anyway)
edit: the CPU is very low on latest update, I tested lowering latency to 112 samples, no issues!! this is great!
geposted Sun 12 Nov 17 @ 2:03 am
