For reporting any bug, questions or comment related to the latest version of VirtualDJ
(NOTE: VirtualDJ continuously updated, so many older topic on this forum are most probably already fixed in the current build)
If you need extended support, contact our Support Team.
Forum Guidelines  (*) The moderators hold the rights to move or modify posts in order to keep the discussions clear or to facilitate the search.
Topic: mapping a button to control window state
how would i map a single button on my controller to minimize the window if it is being shown and to restore the window if it is already minimized.
thanks for any help :-)
geposted Wed 27 Jul 16 @ 12:23 am
locodogPRO InfinityModeratorMember since 2013
minimize
that should do it,
if not you need to toggle a var, query it and minimize : maximize
geposted Wed 27 Jul 16 @ 12:35 am
yeah just minimize didn't do it tried that already
wish i was better with this scripting but i really am not
geposted Wed 27 Jul 16 @ 1:13 am
Did minimize just do that [minimize no maximize]
anyway try this then
maximize 'fullscreen' ? minimize : maximize 'fullscreen'
although alt and tab can switch task without taking up a button
geposted Wed 27 Jul 16 @ 1:37 am
thank you
geposted Wed 27 Jul 16 @ 9:18 am
