Topic: Key Change Mapping Help
I need some help. I am trying to map my Korg NanoKey2 to do tone changes. I have made a script to jump back to hot_cue 8 but my problem now is once I jump back to hotcue 8 i want it to only play when held. Instead what it does is stop if its playing and goes back to hotcue8. If not playing it plays hotcue 8 and continues to play even when I release the hotcue. Any help would be greatly appreciated.
play ? pad 8 & stop : play while_pressed & pad 8 & key_lock & key +12
geposted Thu 28 Jul 16 @ 1:46 am
Change setting 'hotcuemode' to stutter and use this
play ? pause & pad 8 : pad 8 & key_lock & key +12
geposted Thu 28 Jul 16 @ 2:13 am
Thank you, that works perfectly. Now my board is finally done. :D
geposted Thu 28 Jul 16 @ 2:18 am
Actually it isn't perfect,
Imagine you aren't on the hotcue pad page, who knows what the button might do calling for pad 8
2 ways to fix it
1 have the button dedicated to the task
play ? pause & hot_cue 8 : hot_cue 8 & key_lock & key +12
or 2 query the pad page
pad_page 'hotcues' ? play ? pause & pad 8 : pad 8 & key_lock & key +12 : pad 8
geposted Thu 28 Jul 16 @ 2:42 am
