Topic: DECK SELECTION IS SLOW
Hello!
earlier I was using MIXX2.0 and "D" was a hot key to play/pause Desck-1, and L was for Deck-2.
i loved that feature and habitual to that.
is it possible the same way here?
no doubt VDJ8 is superb. waiting for answer.
geposted Fri 29 Jul 16 @ 7:34 pm
you can MAP/Assign any key you want to do anything you want.
In your sample, sure no problem.
geposted Fri 29 Jul 16 @ 7:56 pm
